Upgrading injectors, what size?
Old Jan 14, 2007 | 10:45 AM
HowdyDuty's Avatar
Car: '84 Chevy 1500
Transmission: TH350
I've done some searching on this forum about injector sizes and have come up with mixed conclusions depending on the variables in the formula, so I thought I'd ask the experts.
My engine currently runs about 325 HP and if I calculate right I'm pretty much maxing out my stock injectors, which I'm fine with. I'm planning on adding a turbo to the combo which could push the power up to the 525 HP range. Depending on the variable in the formula I get an answer anywhere from 36LB injectors to 42LB injectors. What's the right answer?
-Howdy
Old Jan 14, 2007 | 12:29 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
The 42s is the right choice in my opinion for a turbo car running 525Hp at the engine.
But, in the meantime, the 42s will be way too much flow without the turbo. So, do not install the 42s until you have installed the turbo.
Old Jan 14, 2007 | 01:52 PM
HowdyDuty's Avatar
Car: '84 Chevy 1500
Transmission: TH350
I found some injectors on an ebay store that are flow matched but I don't know if they're the right style. Can you tell from this description if these will fit?
EV1 plug design
Upgraded 4-orifice nozzle for better atomization
Cross reference with Ford Racing PN M-9593-F302F
14mm upper and lower o-rings
High impedance (saturated) design
Thanks,
-Howdy
Old Jan 14, 2007 | 02:05 PM
Drac0nic's Avatar
It won't matter if he has 42s and no turbo as long as the engine management will recgonize that they're 42s. I'd reccomend figuring out what you're going to do with your ECM (getting a FAST, having a custom chip cut for a 7730 with the $58 code, megasquirt etc.) and upgrade the injectors at the same time as you made your ECM boost aware. Also be aware if you run the $58 code or some aftermarket ECMs youll need to upgrade to a 2 bar (for up to 15 PSI) or a 3 bar (for up to 30 PSI) MAP sensor. Oh, and stay away from Accel injectors.
Old Jan 14, 2007 | 04:06 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
From Ford, you want the ones called EV1 style. I am currently running the EV1 style 24#/hr injectors from Ford Racing.
Concerning Ebay; only go this route if the injectors are coming from a dealer and not a private person. There have been many upset 3rd gen members who did not receive what they thought they were buying on Ebay with regard to fuel injectors. I highly recommend a local speedshop or Summit Racing.
Old Jan 14, 2007 | 06:21 PM
HowdyDuty's Avatar
Car: '84 Chevy 1500
Transmission: TH350
Thanks for all the feedback.
Is it against forum rules to post up the ebay auction where I found the injectors? If not, I could post up the number and get some approval that way.
-Howdy
Old Jan 14, 2007 | 10:51 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
People post up the Ebay auctions all the time. I say go for it.
Old Jan 14, 2007 | 11:21 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
We run the 42's on my GF's RS We drove for months without the blower but still had the 42's and if tuned right it"ll run fine.
Old Jan 15, 2007 | 11:17 AM
HowdyDuty's Avatar
Car: '84 Chevy 1500
Transmission: TH350
Rather than try and post up the link, I'll just post the auction #
42 Lb Injectors: 160073984419
What do you think?
-Howdy
Old Jan 15, 2007 | 01:51 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
From the ebay link, those would work. I cant tell you whether they would be good or not. All I can say is they would work with your application and connectors. For mine I ended up getting a flowmatched SVO Greentops but paid in the mid 400's for them.
Old Jan 15, 2007 | 10:32 PM
HowdyDuty's Avatar
Car: '84 Chevy 1500
Transmission: TH350
Thanks for everything. I'll give these injectors a shot in a month or so. If I have any trouble with em I'll probably post it up.
-Howdy
toronto formula
Nov 10, 2015 06:17 AM
gta90
Sep 15, 2015 04:00 PM
bamaboy0323
Sep 3, 2015 06:07 AM
NinjaNife
Aug 23, 2015 11:49 AM
knight72
Aug 10, 2015 09:32 PM
