Will I need drag radials?
Old Jan 15, 2007 | 07:09 AM
cutnsick's Avatar
Car: 88 GTA Pontiac right hand drive
Engine: 350 CI
Aiming at 300-330 rwhp and going to the track on 31/1/07. Should I just test with my street tyres or not waste my time and buy some drag radials.... The track is generally fairly sticky but wont some opinion of what others have found. I have 2000 stall and 4 speed. (sorry forgot the code)
Old Jan 15, 2007 | 11:01 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
You will always go quicker with drag radials. The key to lower ETs is the 60' time. If you have 16" wheels, look into the BFG TA Drag Radial P255/50R16.
Old Jan 15, 2007 | 11:09 AM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
I'm running 320ish (Dyno'd) RWHP and run the Nitto Drag radials. They do launch better than my old street tires but not better than my newer Eagle F1's. So I'd say it's going to depend on how well you hook up with your stock tires. I'd encourage you to try what you have before sinking money into tires and rims that may not buy you anything (or much).
I put a shoe polish white mark on my sidewall and video taped the launch. Upon review we could see my old street tires spin quite a bit and my 60' time sucked.
Old Jan 15, 2007 | 11:41 AM
jack harrison's Avatar
Car: 1987 pontiac trans-am
Engine: 350 tpi
Axle/Gears: 3;73 with eaton lsd
^^ i did excactly the same thing with the shoe polish!! i have bgd on mine and i tell you what, id NEVER run with out em again!! what i do though is take my rear seats out, put my racing wheels/tires in there and change em at the track. they wont last 5 minutes on the road. im usind 16' wheels from a gta! see my run at http://videos.streetfire.net/search/...3600bdbdce.htm 1.8 60' first run, 1.9 second!
Old Jan 18, 2007 | 04:52 AM
cutnsick's Avatar
Engine: 350 CI
so next question... Whats a good starting point for pressure for street tyres and drag radials? Last time i ran my streets at 28psi (stock + exaust and free mods 14.08 best)
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
fasteddi
Exterior Parts for Sale
Sep 29, 2015 04:30 PM
JSDaddy189
Sep 26, 2015 03:50 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
fasteddi
Sep 10, 2015 09:32 AM
