Homemade cold air intake, need advice...
Old Jan 15, 2007 | 12:29 PM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
Made this using 3" pvc piping and flex couplers. Had to notch away at the radiator / fan support to get it to fit like it does now, but i've still go the problem that the radiator overflow outlet is like right up against the coupler. Any suggestions on how I can change/modify either the intake or the design for the overflow to make this work?
Old Jan 15, 2007 | 03:51 PM
jethawk's Avatar
Car: 1991 Firebird Formula WS6
Engine: LB9
Axle/Gears: 3.42's
drill a hole on both sides of the intake and run the line threw it... thats what i did with mine... but mine was hard ABS so it was fairly easy.. you have a rubber coupler by the looks of it which may make it a little more difficult...
Old Jan 15, 2007 | 04:35 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Here is a link to a picture of what I did.
https://www.thirdgen.org/forums/tpi/...old+air+intake
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
