TPI compatibility
Old Jan 16, 2007 | 10:39 AM
rustbird77's Avatar
TPI compatibility
Hey guys, got a question for you. I'm thinking about buying a Large tube runner and plenum setup for my 89 iroc. The problem is that its off an 86, so is set up for a cold start injector. Can I still make it work with my base, or should I get another base, or just drop the idea all together. Thanks.
Old Jan 16, 2007 | 11:30 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
I think theres a way to block off the cold start. So you can still use it.
Old Jan 16, 2007 | 11:32 AM
rustbird77's Avatar
Is that the only difference?
Old Jan 16, 2007 | 12:17 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
yes, if you plug the hole, you should be all set.
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
