Help lost a bolt.
Old Jan 16, 2007 | 06:44 PM
bigjay89gta's Avatar
Car: 89 GTA
Help lost a bolt.
I have an 89 GTA 350. A bolt the bolts the A/C bracket to the passenger side head fell out and the hole thing is vibrating like crazy. I was wondering what bolt I need to replace it. It is the bolt directly below the A/C Compressor like if you look at the compressor it is at 6 o'clock right below it.
I think it is a m12. But I couldnt find one to fit. ANy help would be awesome. Either you could point me to somewhere i could buy the whole set. Or maybe let me know what the tread pattern and length of the bolt I need.
Jason
Old Jan 16, 2007 | 06:50 PM
Gramps's Avatar
Car: 87 Camaro IROC
its probably 1/2" or something like that, lets say its imperial, what size does it look like you need?(diameter and length)
Old Jan 16, 2007 | 07:21 PM
Car: 89 GTA
I think it is an M12 about 3.5-4' long. I thought it would be metric but it might be standard. I dont know.
Old Jan 16, 2007 | 08:29 PM
Gramps's Avatar
Car: 87 Camaro IROC
if you think its metric but dont know, buy 2 bolts, one in metric and one in imperial. that way you will know for sure if its metric or imperial, but i would guess it to be imperial. what are the other bolts like? are they metric or imperial?
Old Jan 16, 2007 | 09:02 PM
Jaxom's Avatar
Car: '89 IROC-Z
Engine: StealthRam 355
Transmission: 6-speed
Axle/Gears: 3.70 9-bolt
If it actually threads into the head it should be a 3/8" X 16 thread pattern. You can find the length you need by straightening a wire coathanger and checking the depth of the hole. Get a bolt slightly shorter than the hole is deep so you don't bottom the bolt out in the head.
Old Jan 18, 2007 | 04:19 PM
Car: 89 GTA
that is a good idea man thanks for you help.
Thaney9
Oct 24, 2015 07:26 PM
3.8TransAM
Sep 27, 2015 08:37 PM
WhteRbt
Sep 21, 2015 09:48 AM
Abubaca
Sep 20, 2015 09:35 PM
apie2546
Sep 20, 2015 01:03 PM
