What distributor can i use? noob needs help!
Old Jan 21, 2007 | 06:12 PM
quintdavison's Avatar
hi, i have a sbc in a second gen rx7.. i have an opportunity to buy a 305 tpi motor and tranny and all the goods.... i would like to do this, but it is from a 85 camaro.. and i read that it will use the larger hei distributor, is there a way to use the newer tpi small cap distributor, like rewire it or are they totally different? thanks, Quint
Old Jan 28, 2007 | 09:09 AM
toddztoyz's Avatar
Car: 86 Monte Carlo SS
Engine: 5.0 liter High Output w/ TPI
Transmission: built 700R4 Auto
Axle/Gears: 10 bolt 3.73
Because you have an 85 TPI setup, you will have to use the large cap distributor because 85 used a completely different setup than the 86 to 89 and the 90 to 92.
If you get a new wiring harness, computer, and the small cap distributor for an 87 to 88, you can still use you motor with MAF.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
