What is this connector?
Old Jan 27, 2007 | 07:12 PM
azcamaro's Avatar
Car: 1987 IROC-Z / 1992 Corvette
Engine: 305 TPI / LT1
And what/where does it plug into?
I just got this car a week ago, totally different from my carb'ed V6!
Thanks for your help
Attached Thumbnails What is this connector?-connector3.jpg   What is this connector?-con-local3.jpg
Old Jan 27, 2007 | 07:36 PM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
I LOVE those SUNS! I wanna say it goes to the MAT sensor. Hard to see, what color are the wires going to it? If it's the MAT they would be tan and black.
Old Jan 28, 2007 | 02:42 PM
azcamaro's Avatar
The wires are pink/black stripe & black. It has to go somewhere on the back of the motor, hard to get to.
Old Jan 28, 2007 | 03:16 PM
S10Wildside's Avatar
It looks like the EGR Solenoid connector. The wire colors would be PINK/BLACK and GRAY.
Old Jan 28, 2007 | 04:27 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Id say its either for the EGR solenoid or the IAT.
Old Feb 3, 2007 | 10:00 AM
92 Heritage RS's Avatar
Car: 1992 Camaro RS Heritage
Engine: 305 TBI
Axle/Gears: 2.73 open 28 spline
I concurr!! It looks to me like the IAT connector. Gm uses a pigtail connector between that connector and the IAT. Did you just do a conversion or have some one work on your car, or did you get it that way? Your car could have trouble running without that sensor connected. The IAT on TPI cars is located underneath the plenum so check to see if the pigtail is possibly connected and stuffed under there.
Old Feb 13, 2007 | 06:47 PM
1987ZTPI's Avatar
Car: 1987 IROC-Z
Engine: 310 lb9
Transmission: SEMI STOCK 700R4
Axle/Gears: 3.45 9 BOLT
that look the exact same as the connector on my car and it's in the same position as urs and i can't find where it goes . my IAT and egr are hooked up i can't figure it out .
Old Feb 16, 2007 | 04:09 AM
azcamaro's Avatar
Same here both my EGR solenoid & IAT are connected to the wire harness, still don't know where it plugs into.
Old Feb 16, 2007 | 05:46 AM
online170's Avatar
Car: 1987 Firebird
Engine: 355
time for a diagram?
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
