injector clips
Old Jan 30, 2007 | 04:28 PM
rue_69's Avatar
injector clips
Does anyone know where I can get more of those little clips that hold the injector into the fuel rail? I broke a few of mine while changing injectors. thanx
Old Jan 31, 2007 | 08:55 AM
Vader's Avatar
If you are using stock injectors in a stock intake and fuel rail set, the clips aren't absolutely necessary. The injectors should not be able to drop far enough to disengage the upper 'O' rings. However, given the possible variation in machining and injectors, they are a good safety measure, and do aid in assembly.
You should be able to get them from any number of sources. The MSD P/N is 2110:
http://www.msdignition.com/fuel_10.htm
Old Jan 31, 2007 | 09:13 AM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
msd sells them for the lowest price that I found. Also, everyone told me that I didnt need those clips, and im using stock gm 30lb injectors. I tried to fire my car up and there were gas leaks everywhere. I'll use them in every car from now on. Dont need a gas leak lol.
Old Jan 31, 2007 | 09:32 AM
northern-tpi's Avatar
I busted a bunch of mine when taking my old injectors out. I went to home depot and found some snap rings that were a close diameter and then filed some flats on the edges to match the shape of the origional clips. It ended up costing about 50 cents and a little filing time on the vice, but in the end it work our alright.
Old Feb 5, 2007 | 12:06 AM
cutnsick's Avatar
Car: 88 GTA Pontiac right hand drive
Engine: 350 CI
I broke mine too.... Didnt replace them and havent had any leaks, just make sure there isnt enough movement for the o rings to leak.
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
