fuel starvation in hard cornering.
Old Feb 7, 2007 | 07:31 PM
camaro350tpi's Avatar
Car: camaro iroc-z 89
Engine: 383 HSR SC MegaSquirt
Transmission: tko 600
Axle/Gears: 9 Inch 3.75
hi, i just whant to know if your 89 later iroc do the same thing of mine , when you get a hard cornering and have a quarter tank of fuel does your car cuts off for fews second !??? im just wondering if my fuel tank have a .5 galon of reserve...thank for awsering !
Old Feb 7, 2007 | 09:24 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
YES
Old Feb 8, 2007 | 12:58 PM
blackz281le's Avatar
Car: 91 Z28 1le
Engine: 5.7 350 TPI
Are you autocrossing it? If so it doesn't surprise me at all.
Old Feb 8, 2007 | 04:07 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Welcome to the club! Although when I put a walbro 255 in the new ACC gas tank, it didn't do it nearly as bad as before.
Will
Old Feb 9, 2007 | 09:23 AM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
It's a known problem. When autocrossing or open traking I always start the day with a full tank and I try to keep the from droping to less that a half tank.
Old Feb 9, 2007 | 11:58 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Yup, but only when I turn right...
Old Feb 12, 2007 | 02:12 PM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
yep, my 88 is the same way. if im less that 1/4 tank and i make a hard right (like getting on the interstate) it will stall. usually it will just sputter and come back but one time it actually died completely
not a big deal, just a pain in the a$$
Old Feb 12, 2007 | 02:25 PM
Guest
Guest
Posts: n/a
Take it from me, dont auto-x with a low fuel level. lol.
Old Feb 12, 2007 | 07:10 PM
Car: 91 Z28 1le
Engine: 5.7 350 TPI
Old Feb 13, 2007 | 09:33 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
go and get the 1le tankand sending unit . It rotates 360 degrees. It eliminated the hard cornering problem.
Old Feb 13, 2007 | 11:56 AM
Guest
Guest
Posts: n/a
Post a part number for that 'swinging' pickup.
Any 90-up tank has the baffles.
92camaroJoe
Jul 29, 2023 07:57 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
