Where do these vac lines go to? (Pics)
Old Feb 8, 2007 | 09:37 AM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
Where do these two vacuum lines go to? I put blue tape on them where they broke off to make it easier to see. Thanks
Old Feb 9, 2007 | 06:59 AM
i've checked the vac diagrams on autozones website and it doesnt show these two....
Old Feb 9, 2007 | 08:12 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
The top one looks like it should be hooked to a 90 that goes into the bottom of the throttle body. However mine's not routed that way.
The bottom one looks like one of the HVAC/CC line that get plugged into a 3-way check valve that should be in that area.
Old Feb 9, 2007 | 12:05 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
On my '88 there are 2 vacuum ports on the plenum, the one nearest (really doesn't matter which one) the distributor is connnected to the HVAC and the Vacuum Reservior (plastic ball underneath charcoal canister) via a 3-way check valve.
The other port is for the fuel pressure regulator.
If the blue tape is on the end of the same hose it should be from the EGR solenoid to the bottom of the throttle body.
Old Feb 10, 2007 | 12:07 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I actually broke a vacuum line while doing the coolant bypass on the throttle body, so what I did is get a piece of small, medical grade tubing and put gasket sealent on the tips of the line, I then fit both ends into the 1-inch long piece of tubing like a coupler(sp?) or sleeve. Seems to work fine...
Old Feb 10, 2007 | 04:04 PM
Pennocks91ws6's Avatar
Car: 91 formula ws6
Engine: 1 peice roller scat 383 4 BOLT!!
Transmission: 5 speed
2 go under the coil into a rubber fitting, one goes to throttlbody
are these even nessacary tho? i dont know
Nj1987
Aug 19, 2015 08:26 PM
wayshegoes
Aug 17, 2015 12:00 PM
midias
Aug 15, 2015 05:07 PM
cstrobel65
Aug 15, 2015 10:19 AM
sonu1975
Aug 11, 2015 08:38 AM
