valve seals.
Old Feb 14, 2007 | 04:18 PM
avengersteve's Avatar
Car: 1988 firbird formula
Engine: 5.7l pony eater
Axle/Gears: 4.10
valve seals.
replacing stock valve sealson a completely stock motor, which seals should i use?
TIA
Old Feb 14, 2007 | 09:13 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
just go to the auto parts store and grab a set. Really doesnt matter.
Old Feb 15, 2007 | 01:11 AM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
Have to agree it just doesn't matter that much if it's all stock, just put in stock replacement.
Old Feb 15, 2007 | 01:14 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Stock is fine if you enjoy changing the valve seals so much that you want to do it again at regular intervals. Otherwise, you might want to use positive seals instead.
Old Feb 15, 2007 | 09:01 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Whats regular intervals? How long do you think its going to last? I went 100,000 miles on my stock ones before I changed them when I did my cam swap. It puffed a little oil at start up, but nothing major. I just went to Advance Auto and said gimmi the best you have in stock. Now I'm fine besides running a touch bit on the rich side. But I dont puff anymore smoke when I start my car. Anything is going to be better then what he has in there now. Hardest part is going to be changing them. But with the right tools and an air compressor, its not that bad.
Old Feb 15, 2007 | 03:31 PM
Axle/Gears: 4.10
yep got all the tools to make it an easy job, just started smoking a tad... THanks guys~!
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
sleprock
Sep 24, 2015 04:33 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
