Lookin For A Distributor
Old Feb 16, 2007 | 10:43 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
Im searching around for a distributor for my 88 TPI IROC, lookin around but no luck, should i just stick with a stock one? i got some bolt ons, headers, air foil. fuel pressure regulator, and new catco cats, and a crappy granatelli MAF
Old Feb 17, 2007 | 02:40 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
the stock GM distributor should be fine to atleast 350HP, probably plenty more but i forget the exact number. coil is what i would worry about first.
GM HEI article
Old Feb 17, 2007 | 03:04 AM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
The distributor is just a firing mechanism. I run a stock replacement from NAPA and I have no problems at all. I also run a Crane HI-6S and coil with the ignition.
Old Feb 17, 2007 | 04:57 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
The stock external coil dizzy is fine. Just use a good 8 pin hei module (GM/Delco), most aftermarket modules are crap. Use a good cap and rotor like an MSD. I bought a reman GM dizzy (CarDone) from kragens and it works just fine, my original dizzy had worn out bearings and bad shaft wobble. For the external coil, use a good aftermarket coil like the MSD 8226. Also use 8mm spiral core plug wires. All that should be perfectly good for a street motor unless it is extreme. I'm running all that and it works great.
Old Feb 18, 2007 | 01:35 PM
Boosted_SS's Avatar
Car: Cobalt SS/SC and 88 IROCZ
Engine: 383 TPI
Axle/Gears: 3.73 Eaton Posi
if you have your heart set on a distributer jegs and summit have them...i'll get you the links.
Jeg's Brand part # 555-40006
http://www.jegs.com/webapp/wcs/store...72089_-1_10679
Accell part # 110-60109
http://www.jegs.com/webapp/wcs/store...44976_-1_10679
GMPP part # 809-1104060
http://www.jegs.com/webapp/wcs/store...53469_-1_10679
MSD part # 121-8366
http://www.jegs.com/webapp/wcs/store...45370_-1_10679
Summit Brand part # SUM-850200
http://store.summitracing.com/partde...5&autoview=sku
Old Feb 18, 2007 | 09:39 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
MSD part # 121-8366
I have that one on my car. what is the benefit of this one, other than the nice shiny shaft?
Old Feb 19, 2007 | 01:12 AM
Boosted_SS's Avatar
Engine: 383 TPI
lol honestly i have no idea i just found all the distributors i could for the specified application
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
