I have lots of probs.
Old Feb 20, 2007 | 12:06 AM
drop top 89's Avatar
Car: 89 IROC Z/71 dastun 510
Engine: 350 TPI/L20B
Transmission: 700R4/5spd
Axle/Gears: stock/390's
My car is an 89 irocz with a 350 and a 700r4 here is what's wrong.
First, I donno what is wrong with the car. Sometimes I punch it and the rpm's spike and the car doesn't move. Sometimes I punch it and the car moves but slow, other times it just throws me in the seat and it gets. I replaced the TPS and IAC. then the car started to idle at 2500 rpm. Its better now but still idles high(1500, then drops to about 900-1000 when the car warms up) sometimes when i rev it and the rpm's stay up. When I leave it in drive sometimes the gears go a few hundered past the redline.
I really hope someone knows something about this, cause I sure don't.
Old Feb 20, 2007 | 06:11 AM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
Your post is kinda vauge..but when you swapped the two sensors on the throttle body, did you correctly set them? The TPS is crucial to performance, and the IAC is crucial to idling. But to me, sounds like your tranny clutches are starting to go out....anyone else???
Old Feb 20, 2007 | 06:36 PM
I don't know where they are set. My dad is the one that changed them. Well it looks like I am gonna have to take it to a shop and let a pro work on it. As for the tranny clutches do you mean the torque converter? if so I'll just get a high stall converter if that's the case.
Old Feb 20, 2007 | 08:08 PM
Boosted_SS's Avatar
Car: Cobalt SS/SC and 88 IROCZ
Engine: 383 TPI
Axle/Gears: 3.73 Eaton Posi
i agree it sounds like the tranny is starting to slip
Old Feb 20, 2007 | 08:43 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
slow down..... you can adjust IAC and TPS yourself with ease. there is a tech article on the main page. and as for the TPS... well i happen to have somthing that might help:
the tech article is a little vuage on the TPS thing, this pick should help.
but yeah, the not going thing sounds like a tranny to me. looks like it's 5 speed swap time.
Old Feb 21, 2007 | 06:42 AM
techno101's Avatar
Car: 1989 Camaro RS
Higher stall convertor?? What are you talking about?? Clutches mean clutches. Nothing to do with torque convertors. If you not a drag car, high stall convertors will make your gas mileage go to **** FAST! You need to do some reading on setting the sensors, its really easy. You can't just remove one and put on a new one with no adjustments, it doesn't work like that.
Old Feb 21, 2007 | 03:41 PM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
depends on how high of a stall and whether your getting lock up or not.
Old Feb 22, 2007 | 07:16 PM
Ok guys, very helpful info. THANKS!!
Old Feb 22, 2007 | 09:30 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I agree with the tranny going out, have the tranny checked over. Also, you dont just change sensors on EFI cars, especially the TPS and IAC. As stated above, there are tech articles on the home page here on this site. Read the TPS and IAC stuff. And it sounds like you need to set the idle RPM also,, and this has to be done correctly. Please read that tech article also.
RyanJB
May 7, 2016 06:23 PM
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
codeysabatini
Exterior Parts for Sale
Sep 24, 2015 05:40 PM
codeysabatini
Sep 20, 2015 11:36 AM
corey8084
Sep 17, 2015 02:56 PM
