LT1 Cam in a L98?
Old Feb 20, 2007 | 07:49 AM
F-Body Demon's Avatar
LT1 Cam in a L98?
Pretty staight forward q? for yalls, will a LT1 cam work in a L98? Thanks guys.
Old Feb 20, 2007 | 02:01 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
pretty staight forward answer, yes.
Old Feb 20, 2007 | 09:11 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
They're the same cam, except the LT1 has a longer pin in the front to drive the water pump. Cut this pin off to the same size as the pin on your L98 camshaft, and you're fine.
Old Feb 20, 2007 | 09:13 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The specs are so similar, I don't see why you would want to swap. Go aftermarket or leave it alone.
Old Feb 21, 2007 | 03:52 PM
patgta's Avatar
yeah, the LT1 cam is a pretty mild upgrade (i was thinking about doing this upgrade myself). If your willing to go through the trouble of replacing a cam, I would go with at least a LT4 cam.
Pat
lt500r55
Sep 1, 2021 01:30 PM
midge54
Dec 27, 2019 04:14 PM
italiano67
Aug 31, 2015 06:04 PM
midge54
Aug 29, 2015 09:51 PM
TheExaminer
Aug 19, 2015 10:07 PM
