car doesnt idle very good
hey guys whats up? does anybody out there know why my car dies on deceleration braking and it has a shitty idle when in drive(stumbling & surging)??? its a 91 Z28 with a LB9 305. all the sensors are new and everything is set to spec. I was told by mechanic that the #7 & #8 fuel injectors were pretty shitty and some of the others looked bad but not horrible. Any help on this problem would be great Member
Car: 1988 firbird formula
Engine: 5.7l pony eater
Axle/Gears: 4.10
injectors could def. cause that, run a bottle of injector cleaner and see if that helps any, also check your fuel pump and filter
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
