accidently put jumper between terminals f and e on aldl
Old Feb 28, 2007 | 03:37 AM
bmfIROC-Z's Avatar
i accidently hooked a jumper between terminals f and e on aldl in my 86 iroc 305,tpi,700r4 did i fry my tcc selenoid?would this damage the ecm?any help would be greatly appreciated!thanx,joe
Old Feb 28, 2007 | 05:59 AM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
well what happened when you did this? did you hear a pop or see anything burnt or anything?
Old Feb 28, 2007 | 10:57 AM
bmfIROC-Z's Avatar
ACCIDENT
NO none that i remember but my car is surging at low speeds and the tranny is slipping when sswitching gears
Old Feb 28, 2007 | 06:15 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Doing that would not cause the trans to slip at all, the only thing that the computer needs from the trans is 4th gear switch (lets the comp. know when it is in 4th) and tcc solnoid.
Old Feb 28, 2007 | 06:34 PM
bmfIROC-Z's Avatar
SO WHAT EXACTLY DOES THE TCC SOLENOID DO ?AND IF MY ECM IS IN ''BASIC STRATEGY''MODE WOULD THAT CAUSE THE TRANS TO SLIP ,CAUSE IT ONLY SLIPS A LITTLE WHEN SWITCHING GEARS BUT IT NEVER DID THAT BFORE ,KICK DOWN IS SET RIGHT AND ITS FULL OF FLUID.ANY IDEAS?THANX ,JOE
Old Aug 17, 2007 | 02:27 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: accidently put jumper between terminals f and e on aldl
Ive jumped everything in the ALDL and never had a problem with it burning anything or breaking anything ^.^ guess i had good luck
specialized
Jun 18, 2022 09:26 AM
BlueIroc-Z
Jun 9, 2019 03:22 AM
chazman
Aug 28, 2018 03:25 PM
Jae992
Aug 27, 2015 09:07 AM
NBrehm
Aug 25, 2015 11:49 PM
