305 heads on 350
Old Mar 3, 2007 | 02:33 PM
Pennocks91ws6's Avatar
Car: 91 formula ws6
Engine: 1 peice roller scat 383 4 BOLT!!
Transmission: 5 speed
305 heads on 350
good idea?
i was told somewhere that 305s have 55ccs and 350s have 64cc
so if im making a 350, should i put my 305 heads on it? im going to do minor porting and valve relifeing, backcut valves etc
but what will it bump the compression ratio to?? 11:1 or somethign retarded? i dont want to run any higher than 91 octane
Old Mar 3, 2007 | 02:55 PM
Dans87GTA's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 355 Stealth Ram
Transmission: 700R4 w/ 2600 stall
Axle/Gears: 9-bolt 3.27
thats like a postitive and negative deal, yes it does raise rthe compression but 305 heads dont flow nearly as well as 350 heads. so you really dont gain anything. Later Daniel
Old Mar 3, 2007 | 03:12 PM
Car: 91 formula ws6
so,,, i should just go vortec and put some high comp pistons?
Old Mar 3, 2007 | 05:57 PM
Dans87GTA's Avatar
well that wouldnt be a bad idea i have a set of vortec heads sitting in my room waiting to be put on my motor unless i sell them and get a set of alunium Later Daniel
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
st.evel07
Aug 13, 2015 06:15 PM
