What type of piston????
Old Mar 3, 2007 | 06:06 PM
1BadaGTA's Avatar
Car: 1991 Gta trans am
Engine: 383ci,trickflow alum. heads, hsr
Transmission: T-56, alumin. driveshaft
Axle/Gears: stock 7.5"/3.42
Should I go with if I wanted to keep the compression at 10 to 1 or lower with stock iron vortec heads on a 350 l98? Would flat top pistons be to much or what? Or is there something better out on the market?
Old Mar 3, 2007 | 06:27 PM
talover111's Avatar
Car: 1985 & 1988 trans am
Engine: 350 tpi ; 355
Transmission: 700r4 auto; converting to 6 speed
Axle/Gears: 9 bolt 3:27 posi; 2.73 open
try pistons made by keith black or go to jegs.com
Old Mar 3, 2007 | 06:47 PM
talover111's Avatar
flat tops would work hope this helps
Old Mar 4, 2007 | 01:59 AM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
It's not just the pistons but the gasket thickness as well as the deck height of the pistons when installed. They all go together to determine CR, so you have to figure it all in together to find out your true CR.
Old Mar 6, 2007 | 07:09 AM
1BadaGTA's Avatar
ok well that helps alittle but if I put in the flattops would that bring the ratio too high for me too use nitrous if I wanted to down the road? And would any of you guys know about how much I'd gain if I bored it out when I put the flattop pistons in? With a small cam of course.
Old Mar 10, 2007 | 12:21 PM
You can still run nitrous with flat tops. How much power you make depends on the cam.
Old Mar 10, 2007 | 12:50 PM
1BadaGTA's Avatar
Well lets say I go with this motor http://store.summitracing.com/partde...1&autoview=sku
and I put my Tpi injection on top of it. Would you be able to tell me around about what time slip I'd run in the 1/4 mile? I'm looking to see where certain options would take me so I can make my choice without saying "oh man I wish I had done that instead." But I do want the car to be a daily driver too so nothing too radical please.
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
