Serpentine Conversion Question
Old Mar 7, 2007 | 04:52 PM
master486's Avatar
Car: 87 Camaro IROC-Z
Engine: 5.0 LB9 Stock
Axle/Gears: Stock BW 3.45
Hello,
I bought a serpentine setup off of a 90 305 Camaro for my 87 305. Aside from extending the wiring since the A/C and alternator switch sides and using the newer accessories (i.e. water pump), will I run into any other issues? Are the fuel lines different for a serpentine setup as opposed to the v-belt setup? Are there any other components that will need to be moved or might interfere? Any help is appreciated.
Old Mar 7, 2007 | 04:58 PM
TPI Monte SS's Avatar
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
Did you get the power steering pump too? The one on your car is clocked differently, so you'll need the '90 PS pump. As you mentioned, you'll need to extend the wiring for the Alt. and AC. The other connections for the AIR pump are the same, as far as I know. I started with an '87 TPI Camaro harness, and added the serp setup off an '89 (I think) T/A. Worked out just fine!
Old Mar 7, 2007 | 05:04 PM
master486's Avatar
Thanks for the quick reply. Yeah I have the alternator, water pump, power steering pump, and AIR pump all for a 90. It looks like everything for the AIR system will work fine but before I start I'm curious about fuel lines, vacuum lines, and anything else I might have overlooked or not known about.
Old Mar 7, 2007 | 06:18 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
The only other diference is the hard fuel lines on the front of the engine. The hard lines go from the rubber ones on the frame to the fuel rail on the engine. The serp ones are bent slighly different and have a clap that attach them to the alt/PS bracket. You can pick them up from TPIparts.net.
Old Mar 8, 2007 | 09:11 AM
Car: 1988 Monte SS
You'll have no issues with the vacuum lines, since nothing goes in that direction. You might even be able to reuse the existing fuel lines. I have the stock '87 lines coming out of the fuel rail and was able to fit the serpentine bracket with just a few minor tweaks.
evilstuie
Jan 9, 2020 08:29 PM
lt1z350
Aug 28, 2015 05:57 AM
mustangdmurder
Aug 21, 2015 07:17 PM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
