Bogging?
Old Mar 11, 2007 | 11:56 AM
LoneStar666's Avatar
Car: 2005 Pontiac GTO
Engine: 364ci LS2
Transmission: 6 speed
Axle/Gears: 3.46
Bogging?
ok so i think my problem could be one of a couple things... but before i go out buying random parts i wanted to get some input from yall as well.
so every now and then ill be driving my car and the check engine light will come on, doesnt seem to hurt the performance of my motor at all... but it will turn off by itself or just turn off after i turn the car off and start it back up.
also, whenever i give the car gas (maybe half throttle) it feels like a carburator and doesnt have that much power at first, and then a second or two later you feel the car pick up like the fuel pressure was too low.
Ive read about the MAP Sensor and that if its faulty it will cause poor performance, bogging and the check engine light to come on so... do yall think its the MAP Sensor?? and could the fuel pressure regulator and fuel pump have something to contribute to this problem?
my 383 has the stock TPI setup, and appears to be the 15yr old OE MAP Sensor
oh yeah and i hooked the OBDI scanner up to my car and it had a EGR code in its history, im not sure if thats the one that pops up when im driving but it was the only one there
Last edited by LoneStar666; Mar 11, 2007 at 12:00 PM. Reason: Automerged Doublepost
Old Mar 11, 2007 | 08:16 PM
Engine: 364ci LS2
Axle/Gears: 3.46
ttt
Old Mar 11, 2007 | 08:36 PM
maitlandtron's Avatar
Car: 1985 Z/28
Engine: L98 Carbed
Axle/Gears: 9 Bolt Posi 3.45
Best bet would be to check your codes first.
Old Apr 15, 2007 | 04:43 AM
silent-iroc's Avatar
Re: Bogging?
hey this guy maitlandtron i see u gutter ur air box out and cut the screen of ur MAF DO THIS REALLY WORK IN THE AIR BOX CAN I JUST UN SCREW THE BUTTER FLY'S FROM UNDER WERE THE FILTERS GO AND DOES THE MAF WORK WELL WITH OUT THE SCREEN THANKS IM NEW HERE SO THANKS
Old Apr 15, 2007 | 05:09 AM
Car: 1985 Z/28
Engine: L98 Carbed
Re: Bogging?
I actually cut out the entire bottom piece out of the airbox. I will try to take a picture tomorrow. And the MAF works just fine without the screens just make sure you don't mess up the little wire element in there. And always run air filters, not like anyone would run their car with no filters!
pjsparts
Oct 29, 2025 06:39 PM
RedLeader289
May 28, 2019 01:47 PM
Infested
May 22, 2018 11:56 PM
Grant2k
Apr 4, 2016 08:21 AM
middian
Sep 5, 2015 01:42 AM
