Rocker Question
Old Mar 12, 2007 | 02:46 AM
F-Body Demon's Avatar
Rocker Question
Hey guys, I swear im about as good at finding stuff on this site as using the yellow pages . I cant seem to find out if the L98 came with roller rockers or not. So question being what rockers are on her and then, if I added 1.6 Roller Rockers would I actually bring anymore horsepower into play? I know there will be a little from reduced friction in the engine but will the extra lift help any? And then will my stock springs be okay? Im not to sure if I will cause bind or pull the stud, from what I was reading it is AND isnt.
Thanks guys.
Old Mar 12, 2007 | 05:19 AM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
Don't expect a lot but yes you'll get some benifit from the increased lift as well as the reduced friction. Stock are stamped steel 1.5:1 rockers.
Old Mar 13, 2007 | 10:15 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
How much of a difference is there?????? 10 HP maybe?????? What about throtle response?? thanks, Tom
Old Mar 14, 2007 | 08:11 AM
Thats my question (other than the rocker ? thank you btw). Harland sharp (i believe) advertises 10-40! hp gain in the summit catalog so to me that means 5-20 hp, and probably only more than 10 if you have a HUGE cam and your making tons of friction. But i am willing to put money on throttle responce for sure, I mean its not a tuff equasion to figure out: Steel rockers = Heavy, Aluminum Rockers = Light. And according to Smokey Yunik there is hp to be seen from reducing valve train weight, with a 'closer to the valve the better' rule. So maybe when im in there I will upgrade to Titanium retainers while im at it . Pull 20 Hp out of my rear end and no one will notice, until I hit the gas .
Old Mar 14, 2007 | 12:04 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
The effect of switching to 1.6 will probably be a multiplier effect --
minimal (10 hp) for stock, to greater (?? hp) for other mods.
But keep in mind some other factors:
Putting 1.6's onto press-in studs is risky.
Stock center-bolt valve covers can have clearance problems with
some full roller's of either ratio.
Good luck.
Old Mar 14, 2007 | 01:17 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Hey oong distance travler, got the engine compartment all cleaned up, thanks to you..No more Air tubes..........LOL....Thanks for the info on 1.6's......Tom
3.8TransAM
Sep 3, 2015 06:38 PM
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
