Problems with my Edelbrock install. Here was the issue.
Old Mar 25, 2007 | 08:37 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
I am most of the way done installing my Edelbrock Base and Runners. I have run into a couple of problems. I thought I would share them. I had problems with the bolt lengths. The four long lower bolts were not long enough. I had ordered a Stainless allen bolt set the same lengths as the originals. Apperently you can't use the factory lower bolts with the Edelbrock runners!? There are onlt like 4 threads showing past the runner. Has anyone run into this problem? I ended up using a spare set of Throttle body bolts in their place. They are very long but did not bottom out. So I thinh it will be fine.
Also I noticed the two center most bolts on the lower part of the runners enter the intake tracks. I am not sure it did this on the stockers and I used Teflon paste on the threads just in case.
That is a bout all the real problems I had. The larger runner made installation harder cause of the limited space they allow to work in.
Thanx for listening to me ramble.
Old Mar 25, 2007 | 09:33 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Problems with my Edelbrock install. Here was the issue.
I hope you used the right gaskets between the runners and intake manifold. If not you will have a big air leak.
Old Mar 26, 2007 | 07:23 PM
Yes I did. I used Edelbrock lowers and Mr. Gasket 1.75 uppers. I siamesed my plenum and blended all other ports. I did notice there is alot of play in the runners. I could probably move them (1-2)/16" up or down I fired it up today and it sounded great. It reved fast and hard. I will finish up my install of the Ram Air II box for my hood and go for a drive. I'll let you know how that goes.
Old Mar 26, 2007 | 08:43 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Long center bolt in between cyl 5 and 7 passes into coolant. You NEED to put sealant on that bolt.
theshackle
Sep 17, 2020 08:26 AM
Ducati900ss
Sep 2, 2015 09:05 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
86IROC112
Aug 17, 2015 02:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
