I seemed to have lost some power after adding a MSD Blaster coil! is this possible?
Old Apr 4, 2007 | 06:00 PM
jcsereiko's Avatar
Car: 1989 Iroc Z28
Engine: TPI 5.0
Axle/Gears: Stock
I have a 89 TPI 5.0 camaro do I need to change the gap and if so to what? I have SLP runners, custom chip, modified MAF,
Old Apr 19, 2007 | 07:56 PM
Stephen's Avatar
Car: 87 GTA
Re: I seemed to have lost some power after adding a MSD Blaster coil! is this possibl
A bigger/better ignition, will allow you to run a larger spark plug gap.
Old Apr 19, 2007 | 09:30 PM
jcsereiko's Avatar
Car: 1989 Iroc Z28
Engine: TPI 5.0
Axle/Gears: Stock
what gap do U think would be good?
Old Apr 28, 2007 | 04:40 AM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
maybe need to check that the coil mounting is providing a good ground connection. paint, corrosion, dirt, grease, etc.
Old Apr 28, 2007 | 09:45 AM
jcsereiko's Avatar
Car: 1989 Iroc Z28
Engine: TPI 5.0
Axle/Gears: Stock
I am missing a bolt to the bracket that holds it to the motor! do you think that is what it is? I never got one because it seemed to be on good, but if that is a ground then I need one . let me know if that is what you R talking about. Thanks Brother
Old Apr 28, 2007 | 12:06 PM
FormulaL98's Avatar
Car: 88 Formula, 72 Nova, 68 Chevelle
Engine: L98, mild 350, L79 327
Transmission: 700R4, M20, M20
Axle/Gears: 9b 327,10b 373, 12b 331
i recently installed an msd coil on my l98 and i feel that the motor seems to rev easier past 3000 rpm, and yea it always helps to have all the bolts lol
Old Apr 28, 2007 | 09:13 PM
lthrneck's Avatar
Car: 89 Iroc
Axle/Gears: 3.70 9bolt
I put the blaster on and it works great. I did open up the gap to .040 though so you may try that.
Old Apr 29, 2007 | 02:34 PM
MdFormula350's Avatar
I run the msd blaster 2 coil also, .40 gap on my new plugs the car seems to run better. i found out 4 of my 8 wires had like 8000 ohms resistance verses the other wires with only 70 to 200 ohms, found out the connection at the metal end caps were alittle corroded and lose. tighten then up and the car is starting up alittle easier and runs a ad stronger.
its always good over time to pull the coil and check all around it for any cracks from vibrations and stuff, or just have someone start your car and check for arching anywhere in the system.
9192camaro
16
Feb 3, 2019 12:21 AM
stalkier
Dec 6, 2015 11:25 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
midias
Aug 15, 2015 05:07 PM
