Knock sensor, ESC for TPI help
Old Apr 5, 2007 | 04:52 PM
ldo_marlin's Avatar
I am setting up a multi port FI system using the 1227730 TPI computer. Would like to run knock. What knock and ESC sensors does this system use? From the ACdelco website, it specifies a #213-920 10485432 knock sensor. But i could not find an ESC #. Does it use a knock and an ESC sensor like the TBI system or is it differrent.
Old Apr 8, 2007 | 12:21 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Re: Knock sensor, ESC for TPI help
I am not sure , but the only info I can offer you is ....there are two different knock sensors ... one for the 350 and one for the 305
Old Apr 9, 2007 | 08:09 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
To make it easy for you, not knowing what computers came in what cars.....
Ask for a knock sensor out of a 92 350 TA. That's my car with the same computer.
Old Apr 9, 2007 | 10:25 AM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
well both are different from 305 to 350. checkout tpiparts.net for the knock sensor and the ESC module. just make sure you get the right one for your application.
stalkier
Dec 6, 2015 11:25 PM
bamaboy0323
Sep 3, 2015 06:07 AM
db057
Aug 22, 2015 08:17 PM
Sanjay
Aug 12, 2015 03:41 PM
