Coin in the FPR trick?
Old Apr 8, 2007 | 08:50 AM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
I have heard the story of increasing the fuel pressure by installing a coin in it. What coin do you use ( nickle is thicker than a dime..and so on) and what is the approx gain. I am going back to the stock FPR and throwing my leaking ***, noisy Holley POS in the garbage.
Old Apr 8, 2007 | 08:58 AM
firstfirebird's Avatar
Re: Coin in the FPR trick?
Check out what 83crossfireTA did to his to make it adjustable...
https://www.thirdgen.org/forums/orga...ovement-2.html
I cut the spring out of mine and used an inline AFPR in the return line.
Old Apr 8, 2007 | 09:26 AM
Rob Wade's Avatar
I posted a question about doing this a while back. Got no response. Something like this? http://www.aeromotiveinc.com/pdetail.php?prod=15
Would you install it in the feed line or return. What do you do with the stock? Just cut the diaphram so its just a gasket and plug the vacuum port? I like the fact that you can locate it away from the plenum.
Old Apr 8, 2007 | 09:52 AM
As I said, I cut the spring and put mine in the return line. No need to plug the vacuum port if you cut the spring because the diaphram will still be there.
92-Formula
Dec 12, 2015 10:34 PM
mike22115
Sep 28, 2015 04:49 AM
RS Reaper
Sep 27, 2015 07:04 PM
Lmancha96
Sep 25, 2015 08:11 PM
Strick1
Sep 4, 2015 07:11 AM
