Plenum porting, taking out peice between the 2 intake holes?
Old Apr 10, 2007 | 04:09 PM
speedmachine's Avatar
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
hello
I am planning to mega port my plenum. I plan on using the stock tb.
Just so can picture it, think of the front of the plenum with the two circular ports. What i was thinking about was taking out the middle part between them so the front of the plenum would have a big almost oval on the front of it.
My thinking is that it would increase plenum volume a little bit.
porblems, thoughts,opinions about this?
Lee
Old Apr 10, 2007 | 04:41 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Plenum porting, taking out peice between the 2 intake holes?
Well that is what I'm going to do on my next round of mods. However I'm going to a monoblade.
Do some research on intake manifolds such as the Superram and Stealthram. I thought I remembered one of them with a big oval in the front for the throttle body like you described.
Old Apr 21, 2007 | 07:43 PM
Car: 1989 IROC-Z
Engine: 346 LS6
what i had in mind was something like this, will this create problems for me [false sensor readings?], i am using the stock throttlebody.
Speed
Attached Thumbnails Plenum porting, taking out peice between the 2 intake holes?-tpi1.jpg
Old Apr 22, 2007 | 11:09 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
that looks pretty mean, I want to know how that worked out for you
I knocked the restrictive walls between the runners and smoothed the area where the air starts to go into the runners from the pleneum.
the motor is all together but I am going to do the same thing to my buddies pleneum for some pics
I also opened the ports on the runners where they meet the pleneum and simeased then about a half inch into the aluminum plate the the runners slide into
it made some good power in my 305
Old Apr 22, 2007 | 12:24 PM
Car: 1989 GTA
Engine: 369 TPI
I don't see why you would get false sensor readings. The two holes in the bottom are for the EGR and the PVC valve.
Old Apr 22, 2007 | 12:45 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
I don't think that taking that out would have any effect unless you got a monoblade throttle body. If you get one on there, then that would deliver MUCH more air to the runners, however, you are going to have to port the hell out of the rest of the plenum to gain the effects you want. Hi flow runners work well too.
MantyZ28
16
Dec 21, 2015 11:02 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
89mulletbird
Aug 12, 2015 07:08 PM
Jake_92RS
Aug 11, 2015 10:39 AM
