Please Verify My Result
Old Apr 13, 2007 | 07:29 PM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
I have an afterfire problem, can't press the gas pedal with out firing in the exhaust pipes. I have a list of things to check, and I have come to the knock sensor. I have a good one, new/unused that measures exactly 100k ohms. (positive lead in the male output, negative to the metal case surrounding it) I've measured the one on the car and got infinite resistance.
This does mean my knock sensor is bad and is most likely the source of my problem? I'm closing down for the night and I wanted a couple opinions before I douse my floor in coolant tomorrow.
Thanks..
Eric
Old Apr 14, 2007 | 09:57 AM
Vader's Avatar
Re: Please Verify My Result
Try running with the EST bypassed, or scan the ECM for knock counts while running. With the ESC inactive, there should be no retard. If the afterfire continues in EST bypass mode, the ignition timing is not likely the problem, unless it happens to be late as a result of late cam timing. Verify the base timing to be certain the cam timing has not changed.
Old Apr 14, 2007 | 10:58 AM
BOSS 357's Avatar
Engine: 357 SBC TPI
OK, I'll try that...but my KS is bad right?
Old Apr 15, 2007 | 03:18 PM
Vader's Avatar
Not necessarily. A resistance test is really only a relative indication. A test with an oscilloscope would be more conclusive.
Falcon50
Aug 22, 2020 03:26 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Thornburg
Oct 6, 2015 12:04 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
