AFPR SETTING
Car: 1987 IROC-Z
Engine: 310 lb9
Transmission: SEMI STOCK 700R4
Axle/Gears: 3.45 9 BOLT
AFPR SETTING
I just installed an AFPR i was running 40psi at idle and 45 when i disconnected the vacum line i'm told that stock pressure at idle should be 42-43 psi , i have a bunch of bolt on headers wires , pullies full exhaust , also msd 6a and coil as well as a programed E-PROM , tb air foil and port and polish on the upper plenum and runners . what is a good pressure to start off at i've been told that 46psi at idle will give you better performance even on a stock motor any input would help thanks
RYAN
RYAN
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: AFPR SETTING
5 psi difference when pulling the vacumme line? Mine was 43 psi with line on or off. In fact it's never made a difference for my car whether the line was on or off.
I upped mine to 50 psi and it seemed to have better throttle response. Better midrange power.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: AFPR SETTING
Pressure at idle should be 42-43 psi with the vacuum line off. 37-38 w/it on.
Unless you do a custom chip, that is where it should be.
Car: 1987 IROC-Z
Engine: 310 lb9
Re: AFPR SETTING
well not sure about everything i'm hearing cuz with the pressure at 49psi at wot and 44 at idle the car runs alot better it idles way smoother it idles at 650rpm and it just feels smoother it kind of feels the same or a tad slower than befor when accelerating but that mite be because it's 2 degrees outside but it feels alot better to me.
AND I DO HAVE A CUSTOM BURNED CHIP
Re: AFPR SETTING
Was it burned for 49 psi @ WOT?
It so, that's why it runs better there.
Car: 1987 IROC-Z
Engine: 310 lb9
Re: AFPR SETTING
not sure if it was programed for that pressure , when i gave the guy my mods lisy he said i should put in a 165 degree thermostat and maybe an adjustable fuel pressure regulator to help tune it better .
82tabird
Dec 21, 2015 10:22 PM
[Sold] Accel 30# injectors
hydrolic144
Aug 29, 2015 04:14 PM
355tpipickup
Alternative Port EFI Intakes
Aug 26, 2015 04:08 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Aug 24, 2015 06:52 AM
mustangdmurder
Aug 21, 2015 07:17 PM
