All Vortec TPI Swappers...Cooling Question
Old Apr 15, 2007 | 12:36 PM
steve88iroc's Avatar
Car: 1988 IROC-Z
Transmission: WC T5
Ok guys, I'm almost finished with my vortec head swap, and I have to tie up a few loose ends. For those of you who have done the swap, what did you do with the extra cooling port on the front of the manifold? Did you plug it, or did you tee it into a line somewhere? I've included the SDPC instructions below, but they aren't that clear. BTW, I'm using my orignal block, which is from 1988. Any help would be appreciated.
"Special Note: If you are using a 1996 or later Gen 1 Chevrolet block, then you must route a coolant by-pass line from the intake manifold to the water pump. The 1995 and earlier blocks are machined with the by-pass provision in the block. The by-pass line must run to the passenger's side outlet on the water pump using a 5/8" hose."
Steve
Old Apr 15, 2007 | 02:04 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Re: All Vortec TPI Swappers...Cooling Question
The hole for conventional blocks(pre 96) is already there.
Later blocks dont have it and need the bypass.
Although I've often wondered if a restricted line from the manifold to water pump might help warmup time some.
later
Jeremy
Old Apr 15, 2007 | 07:51 PM
Car: 1988 IROC-Z
Transmission: WC T5
Thanks,
So I just plug the hole in the manifold with a pipe plug and I'm good to go then?
Steve
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
