350 TPI Knock Sensor Interchange w/ 350 TBI Knock Sensor?
Old Apr 16, 2007 | 11:18 PM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
There seems to be some ambiguity about this. Autozone shows a PN of SU169 for a wells unit that is for the 1991 350 TBI trucks as well as the 1991 350 TPI SD cars. Anyone know if they are interchangeable as long as the engine size is the same? I bought a TBI 350 knock sensor many years ago for a TBI swap and it is currently installed in my block. I am know going TPI and am wondering if I need a TPI-specific sensor.
Old Apr 16, 2007 | 11:27 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 350 TPI Knock Sensor Interchange w/ 350 TBI Knock Sensor?
Measure the resistance of it. The 85-89 TPI sensors are 100k ohms, and the 90-92 TPI sensors are 3900 to 4400 ohms. If it measures 3900 to 4400 ohms, you're fine.
Old Apr 17, 2007 | 12:57 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
In the TPI's there is also a differance in the 5.0 to 5.7 L knock sensors
bamaboy0323
Sep 3, 2015 06:07 AM
Keith5
Aug 27, 2015 04:37 PM
CamaroGuy350
Aug 26, 2015 05:11 PM
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
