TPS .54v or .71v????
Old Apr 28, 2007 | 10:59 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
I have a 89 rs 305, that the previous owner heavily modded, its now a MAP tpi, no maf sensor. I read at iroc zone that the tps should be at .71 for map cars, is this true?? I put it at .54, it was at .46 before. Does it need to be .54 or .71, im confused.
Old Apr 28, 2007 | 11:16 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: TPS .54v or .71v????
I do not have a MAP car, but I would think that the TPS should be set the same for either. Set it at 0.62 to 0.64V, thats where I am running my MAF car.
Old Apr 29, 2007 | 08:47 AM
djr_678's Avatar
Car: 98 T/A 94 dodge ram
Engine: LS1/ 5.9
Same here .62v
Old Apr 29, 2007 | 09:34 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I'm running both my MAP and MAF at .55
Old Apr 29, 2007 | 06:24 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
TPS should always be between .5 and .6
im running .55 on my MAF, also check it at wide open throttle and make sure it reads close to 5 volts max. if it doesnt then u need a new TPS
Old Apr 29, 2007 | 06:27 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
does anyone of a pic of were to test it at?
Old Apr 30, 2007 | 12:04 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
I put it to .61, camaro racer, on the PS of the throttle body is the tps, its got two torx screws, you stick the black in "A" and red in "B"
Old Apr 30, 2007 | 01:56 PM
Car: 87 TA clone
thats one way, just use a code scanner, i used one and it reads the TPS voltage. u could do it that way if u want tho, its ont he passenger side of the TB, its black, 2 torx screws and be careful tighting them they are aluminum and u could snap them off or break the TPS.
92camaro350cci
Oct 14, 2015 09:29 AM
Fred SS
Oct 12, 2015 11:27 AM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
