TPI Questions
Old May 9, 2007 | 07:10 PM
Camaro1996's Avatar
TPI Questions
Hey guys whats goin on? Im new to the board. I have a 4th gen right now and I'm thinkin about gettin an IROC, since they are sweet! What kind of power can I get out of a 350 TPI setup with some basic mods? That setup is basically an old school 350 with a 'new' fuel injection system right?
What would be necessary for ~350 RWHP?
Old May 9, 2007 | 10:34 PM
Gramps's Avatar
Car: 87 Camaro IROC
Re: TPI Questions
an LS1 or a crate engine.
basic mods might get you up to 300net hp, so like 270 at the wheels
Old May 10, 2007 | 09:51 AM
LoneStar666's Avatar
Car: 2005 Pontiac GTO
Engine: 364ci LS2
Transmission: 6 speed
Axle/Gears: 3.46
Re: TPI Questions
if youre working with the L98, having the heads ported/intake base ported/intake plenum ported/aftermarket intake runners/ headers/ full catback exhaust/ 3.42-3.73 rearend gear/ and an aftermarket cam....
that should have you around 300rwhp and over 400ft/lbs
Old May 10, 2007 | 10:22 AM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
Re: TPI Questions
stroke it, and a harry cam.
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
