quick question
Old May 9, 2007 | 09:42 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
quick question
i have an 88 trans am gta with a 350 motor in it. i just bought an S.A. gear performance timing gear set and it has the ability to advance or retard the timing of the camshaft to 4 degrees.. what would the effects be if id advanced it or retard it... would the car sound any different.... i also have long tubes im putting on also and some 1.6 rockers along with an full flowmasters exhuast... with that combo how would the car sound....
Old May 9, 2007 | 11:53 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: quick question
Don't worry about advancing or retarding the timing set, just install it "straight up". Changing the cam timing is a way to fine-tune the engine's powerband, or to correct for a slightly mis-ground cam.
Old May 10, 2007 | 12:32 AM
88fastgta's Avatar
Re: quick question
but how would the cam sound... would it be like putting in a new cam that already has those settings or what... whats the advantage of doing that....
Old May 10, 2007 | 12:40 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: quick question
It will have no effect at all on the sound.
Old May 10, 2007 | 12:44 AM
88fastgta's Avatar
Re: quick question
so the only way to change the idle of a car is to put a different camshaft in it like the powermax 2032 cam..
Old May 10, 2007 | 12:45 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: quick question
What are you trying to accomplish?
Old May 10, 2007 | 12:52 AM
88fastgta's Avatar
Re: quick question
well basically all i want to do is make the car sound off idle or let people know that it has a cam in it... i dont want to change alot of things to make it work like heads and intake... i just want a nice rumble to my engine at idle...
Old May 10, 2007 | 12:55 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: quick question
Concentrate on the exhaust then, and don't worry about the cam. There's not much you can do with the cam to affect the idle that isn't going to annoy the computer.
Old May 10, 2007 | 12:58 AM
88fastgta's Avatar
Re: quick question
well i already have headman long tube headers and full flowmasters exhuast system with the high flow cat on the car already........ is there anything else i can do
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
