Code 45
Old May 10, 2007 | 01:02 PM
guitargod's Avatar
Code 45
89 Formula 350 is throwing a code 45 which is the rich exhaust. Any suggestions on what i should check/replace first.
Old May 11, 2007 | 07:01 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Code 45
Common Trouble Code Solutions
Code 45 ~ Check evaporative charcoal canister for smell of fuel (which normally comes from filling fuel tank to full). check fuel pressure regulator. Possible leaking fuel injector or sticking/bad EGR valve. Possible bad Oxygen sensor.
http://gmtips.com/3rd-degree/dox/tip...es/code-01.htm
"Search" is good
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
