Who wants to spend my money for me?
Old May 14, 2007 | 03:07 PM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
Well FINALLY my insurance settlement should be coming through. (got rear ended by an escalade while sitting still on my bike last year, broke my back in 2 places, totalled my BEAUTIFUL GSX-R 750, and left me in the trauma center! )
I should have about $1500 to invest into my motor.
Im thinking Vortec heads, LT4 hotcam, and some high perf runners. How bad is a TPI setup with ported pleneum, 58mm TB and ported base? Can i make it flow well enough for a hotcam to reach its potential?
Maybe i should leave this more open ended, how to i make the most out of $1500 under my hood? Im looking for heads/cam/intake. my block is in really good shape for 110k miles. I think the 2.77 gears are to thank for that. (unless im really thrashing it it never goes above 2500rpm) Its a roller block, so my cam choices are somewhat limited but summit sells a complete LT4 hotcam kit for like $500 with 1.6rr's and pushrods, springs, the works!
Also, who makes a TPI base that will fit vortecs? Can i modify my base to work?
Spend my $1500 for me!!!
Old May 14, 2007 | 04:29 PM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
Re: Who wants to spend my money for me?
really hoping you got more then 1500 for that much bs. my dad got his back broke by a train and it catches up with you with age
Old May 14, 2007 | 04:38 PM
Car: 88 IROC
oh im getting much more than that. but im getting out of debt (not too bad, about $3k) and paying for school. Im also doing a t56, new rear end, c5 wheels, and c5 brakes on this money. $1500 is just what i have to put into the motor
Old May 14, 2007 | 04:53 PM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
ima start lookin for escalades...
and sorry to say it but the mustang in the denso iridium ad up top of the page looks damn nice
Old May 15, 2007 | 02:55 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Personally, I'd spend the money on the heads, cam & intake base, rather than runners - the reason for that is that you're going to have the entire intake off anyway to add the heads & cam, you might as well install the base while it's already taken apart!
Then, when you have the money for runners, adding those will be a piece of cake! (Compared to pulling the intake again...)
Whichever route you decide to go with it, good luck, with the car, & with your back.
RedLeader289
May 28, 2019 01:47 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
HoosierinWA
Oct 7, 2015 10:15 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
