heated o2 sensor part no.
Old May 25, 2007 | 08:12 PM
Nails's Avatar
Car: 1987 z-28 Camaro
Engine: 350 l-98
Hi all, anyone know the ac delco part no. for the heated o2 sensor (phoned
dealer and they only listed the single wire one.) It is for a 87 camaro with
a 350.
thanks
Nails
Old May 26, 2007 | 12:22 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: heated o2 sensor part no.
Ask him to look up one for a 93-95 ZR1 Corvette. Or a 93-95 LT1 Camaro/Corvette.
They dont come plug and play for a thirdgen however. You will need to modify the connector.
Old May 26, 2007 | 07:18 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Stock is AFS-20
3 wire heated is AFS-74
later
Jeremy
Old May 26, 2007 | 07:26 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I use a Bosch 13077 for a 92-93 LT1 Corvette. Simple 3 wire hookup, power,ground and signal.
Old May 26, 2007 | 07:55 AM
Stevo's Avatar
Car: Pair of 92 Z28s
Thats funny i was just looking for a part # last night. Hopefully one of the part #s you guys listed i can pick up at a local autoparts store.
Also found #2517670
On Summit if you type that in it a catco o2 sensor comes up:
http://store.summitracing.com/partde...5&autoview=sku
As long as they fit in the o2 bung any 3 wire would do right?
Old May 26, 2007 | 09:34 AM
Nails's Avatar
Engine: 350 l-98
thanks for the help guys. I'll see if i can get the one for the 93-95 camaro.
Nails
Old May 26, 2007 | 10:35 AM
Stevo's Avatar
I had him look up a 93 vette, and they were all single wire. He looked up a 93 ZR1 and i matched the part # that one of you guys listed. Its a Bosch 13077 3 Wire o2. 1 year warrantee only cost me $61.48.
86IROC112
Nov 27, 2015 09:54 AM
85 Jimmy
Sep 30, 2015 07:56 AM
mfp189
Sep 27, 2015 09:25 AM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
