Help Please
Old Sep 14, 2000 | 06:29 PM
Tay's Avatar
Tay
Car: 1990 Trans Am GTA
Engine: LB9
Help Please
I changed valve seals, but car still smokes at wide open throttle. Doesn't smoke at start up anymore. I couldn't tell what color it was because it was dark. A mechanic said it could be running rich or lean. Any help is appreciated.
Old Sep 14, 2000 | 06:33 PM
Kevin G's Avatar
It could be running rich. Usually it will be a black suit type smoke..
Also your rings could be worn out, causeing an oil smoke, which is a little greyer.
Hey, at least you fixed the start up smoke problem
Old Sep 14, 2000 | 06:34 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Oil smoke at wot isnt caused by valve seals, its caused by worn out rings/bore, or a bad intake gasket sucking in oil from the lifter valley
id guess that your engine is just a little tired and needs a rebuild if you havent messed with the manifold or anything
smoke at wot could be a rich condition aswell but it wil lbe black smoke and not the greyish smoke that oil looks like
Old Sep 14, 2000 | 06:48 PM
Tay's Avatar
Tay
Engine: LB9
Thanks for the quick response fellas, I will try to see what color the smoke is today. How much is a ring job run, or should I save for a rebuild?
