Confused about timing on 89 Formula 350
Old Sep 12, 2000 | 12:59 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I went outside to check the timing ,so I marked the line on the balancer with white paint ,but on the tab I cant read teh degree numbers because of surface rust. I don tknow if each notch is 1 or 2 degrees. S oanyway I put the timing gun on and turned it on and the line onthe balancer is PAST the whole freaken degree tab. Whats this mean?
Old Sep 12, 2000 | 02:09 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Means you did not disconnect the EST line...on the '89 it should be located behind the pass. side strut tower, a single wire connector...tan/blk...disconnect it, then look at the timing.
If I recall...the mark way to the right is 2 degrees ATDC, then 2 degree incremonets going to the left on each "point"..so all the way to the left is 10? or 12?*'s BTDC.
Old Sep 12, 2000 | 02:12 PM
Hank Brote's Avatar
Mike,
You have to disconnect the EST lead in order to read the base timing of the car. The EST lead is located on the firewall around the Air Conditioner core and the fan unit. It is a single brown lead with a connector on it. Once you disconnect this lead (at the connector) you will read the timing (Base)without the computer adding timing. The biggest "V" (Center of the V) on the timing tab is 0* The next "V" above 0* (Center of the V) is 6* BTDC. Remember that the portion of the tab with the most scales is BTDC.
Hank
87'IROC Z28
Old Sep 12, 2000 | 02:22 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Ok guys I disconnected the wire and at idle the mark is that the tip of the first point left of the 0 mark. So that would be 4 right? If I was to move it up to 8 I would have to set it at the 2nd point?
Old Sep 12, 2000 | 02:34 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
why dont you just get a small peice of sandpaper and clean off the surface rust by hand? I did this, and then sprayed a little bit of aluminum color engine paint on it, easy to read now and took a grand total of 5 mins to do
Old Sep 12, 2000 | 02:39 PM
Hank Brote's Avatar
Yes, that would be 8*
Hank
87'IROC Z28
Old Sep 12, 2000 | 03:04 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
How the hell do you loosen the distributer up? I cant get to the friken bolt?
Old Sep 12, 2000 | 10:14 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
I can reach mine with a long extension. You may have to loosen your coil and push it to the side.
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP cam, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax/Flowmaster catback
Coming Soon - Fasttrack/Accell DFI
SOLD ->91 Z28, 5.7, 3.23, Ported Plenum, Accel runners & lower intake, Accel distributor module, !dual cats, POS Edelbrock catback, K&N'S, ram air, tb airfoil, !tb coolant
Coming soon - Compucar N20 kit, Accel AFPR
Old Sep 12, 2000 | 10:28 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
i cant get a socket between the bolt and the distributer plate (where the cap mounts too)
Old Sep 12, 2000 | 11:34 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
I beleave I use a 9/16 crow's foot with a long extension, if thats what you call it.
89 GTA 350 5-speed
Jet hot coated SLP headers,flowmaster force 2,no cat's,SLP cold air,MSD 6al,jet chip stage 2,march pulleys,ported plenum,air foil,B&M ripper shifter,180 stat,alston SFC,spohn LCA relocation brackets,MAT relocation kit,free mods.
0-60 5.48s
E.T. 14.02@98.9MPH (corrected)
Old Sep 12, 2000 | 11:35 PM
Tony89GTA's Avatar
Car: 89 GTA
Double post.
[This message has been edited by Tony89GTA (edited September 12, 2000).]
Old Sep 12, 2000 | 11:50 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Yeah that or something I added to my bunch o' tools a long time ago called something like a "distributor wrench."
And yes, it's a pain to get to at first sight, just move the coil or loosed the coil to gain better access to the bolt. it's really not THAT bad.
Old Sep 15, 2000 | 10:20 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Sears Hardware sells several distributor bolt wrenches which have about a 4 inch off set.
I bought one and it works OK, still very tight in there but I can loosen and tighten the distributor bolt.
To get more room if you have the external coil like my '87, you can remove the 2 bolts that hold down the coil and move it and that plastic vacuum thingee out of the way.
And I agree with Hank, the second peak is 8* advance if to the left as you stated.
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 2400 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(48psi), K&N filters, Hotchkis lowering springs, Car-Pro custom chip, Lay Ind. ram air kit, 265/45R16 Kumho V700 tires.
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter.
313.7Hp & 320.6ft-lbf, 13.55sec @ 105.1mph
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Sep 17, 2020 08:26 AM
okfoz
Mar 9, 2017 02:35 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
