would this swap work?????????
Old Sep 18, 2000 | 09:31 PM
Monkie's Avatar
Does anyone know if a ZR1 engine from the corvettes fit into a 92 Camaro???? And if so what would have to be done? And would it be worth it? Or would I be better off getting a 96 LT1 engine?
Old Sep 18, 2000 | 09:47 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Don't know if the swap is possible, but GM had the ZR1's on clearance for 12G's. That included accessories, brackets, plugs, wires, sensors, etc... Probably way easier to do the LT1.
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
If you live in Southeastern US, check us out!
South East Thirdgen
Old Sep 18, 2000 | 10:04 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
It'll fit. I've seen a pic in the Camaro Performance Handbook which had it in there. Very tight fit though
Frozer!!!
Jan 19, 2024 04:55 PM
Jorlain
Aug 24, 2022 05:11 PM
jharrison5
Aug 19, 2015 05:53 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
