How much power...
Old May 30, 2007 | 11:14 PM
s10irocspikes's Avatar
Car: 86 IROC
Engine: 350 Miniram
How much power...
How much power will the mass air TPI support? Is there a limit to power until the mass air meter is either restrictive or cannot measure airflow efficently?
Old May 31, 2007 | 07:31 AM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Re: How much power...
The MAS is not a serious restriction to power (once you gut it) until the engine reachs around 550 HP. The sensor itself can no longer monitor airflow changes (it is maxed out at 255g/s) once you reach approximately 450 HP, you can still tune the system to operate at more then 450 HP but is will not be able to sense minor changes in the atmosphere and make the necessary changes.
Old May 31, 2007 | 10:44 PM
Car: 86 IROC
Engine: 350 Miniram
Excellent reply. Thank you very much. Nice times by the way. I just bolted on a set of AFR's. Hoping for the 12's as well.
Old Jun 1, 2007 | 04:42 PM
87-4MULA's Avatar
Car: 1987 Firebird Formula
Yeah i think the stock one will flow at about 529 cfm but i beleive TPiS makes one that they have tuned to flow 750 cfm
alpine247
Brakes
16
Jan 11, 2008 11:45 AM
murky024
Dec 28, 2007 10:32 PM
orangetang
Jun 3, 2005 06:39 PM
