HELP WITH PLUG WIRES ???
Old May 31, 2007 | 01:14 PM
hung4wheeler's Avatar
Car: 87z28
Engine: 70 LT1
Transmission: 350 TURBO BUILT BY B&M
Axle/Gears: 12 BOLT POSI
I NEED TO KNOW WHAT PLUG WIRES I CAN USE ON MY 86 305 TPI MOTOR AND WHO MAKES THEM AND WHAT SIZE ..MY ORIGINALS ARE 8.8 MM HIGH SUPPRESTION
Old May 31, 2007 | 01:59 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Re: HELP WITH PLUG WIRES ???
MSD's go on everything I own anymore.
Best for heat resistance and last long to boot.
Personal preference but I've used them all and will stick with the MSD.
later
Jeremy
Old May 31, 2007 | 02:20 PM
BA92GTA's Avatar
I have in the pass used other name brand sets but agree with above post.
For performance and sure fire of the spark pulgs I used Copper Core wires. These are wires with a copper wire inside of them. There pricey but when hitting a 350 shot of NOS I cant afford a missfire.
Old Jun 1, 2007 | 06:32 AM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
MSD have good header plug wires too? Can someone tell me the P.N. they use? Mine is for a 305 tpi also with hooker headers.
Old Jun 1, 2007 | 07:42 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Pretty much any set of wires will work for you.
If you want custom wires (for the TPI) you'll have lots of slack.
If you want a cleaner look (less slack) get universal wires. You cut those to fit. Any name brand will be fine.
You could even just go to your local parts store and get a set of wires for your car.
All you have to make sure is that you get all 90 degree boots since you have headers.
eightsixseven
Dec 16, 2024 01:50 PM
Thornburg
Aug 30, 2015 08:05 AM
g.l.mos
Aug 22, 2015 12:02 AM
djmarch
Aug 19, 2015 12:07 PM
