Codes 33 and 34, GRRR!
Old Sep 24, 2000 | 10:55 PM
T/A1988's Avatar
I gotta tell you I'm getting a little pissed off here! I got these codes(33 and 34), so I figured it was time for a new MAF. I went to Advanced Auto and picked up a remanufactured Bosch MAF. I put it in and the car still stalls if it starts at all. I unplug the MAF, runs like a dream. What the hell? Anybody know what's going on?
Old Sep 25, 2000 | 12:19 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Check
-TPS voltage
-MAF power relay
-Burn of relay
and the archives for this one.
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTB, ported plenum, 52 TB, MSD 6AL, TPIS level V prom, Mod .MAF, Superior shift-kit and some minor mods. and more to come!
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Old Sep 25, 2000 | 06:52 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
Check your connections for corrosion too, especially the weatherpack to the MAF Sensor, it can get pretty bad.... Clean the contacts with a jeweler's file and some TV tuner cleaner or rubbing alcohol..... If that's the problem, at least you have a new spare MAF Sensor.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Cyclone Fuel Pump, JET Airfoil
Veiw my car at: http://www.geocities.com/transam85tpi/TransAm.html
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
