L98 rods
Old Sep 23, 2000 | 01:59 PM
kwikgta's Avatar
L98 rods
Are the factory 5.7" rods in my 92 GTA, powdered metal like the ones used in the GM crate motors?
I am building a 383 this winter,I will reuse them if they are.
92 GTA(only 226 made)ort matched sportsman heads with 2.05 valves,64 cc,milled .015,.028 head gaskets,port matched Accel runners,port matched plenum,port matched edelbrock intake,flow matched injectors,jet hot headers and 2.5" mandrel bent exhaust,Flowmaster muffler,underdrive pulleys,slp cam,1.6 rockers,slp cold air induction,52mm throttlebody,performance resource custom chip,Dyna module,Screamin Demon coil,Accel 8.8 wires,Bosch platinum plugs,timing at 10 degrees,tb bypass,relocated map sensor,shift kit,Fairbanks billet servo,pump vane kit & 2400 stall,Torque converter lockup switch,3.42 posi with welded axle tubes,Zexel Torsen HD diff.,Summit rearend girdle,solid pinion spacer,& alloy axles.Boxed panhard bar,lakewood lca's & edelbrock strut tower brace,Jeg's torque arm,Jegs welded in subframe connecters.Performance friction pads,turbo slotted front rotors,stainless braid brake lines.Roh ZT 17x8.5 front wheels with 255/40ZR/17 tires. 17x9.5 rear wheels with 275/40ZR/17's on the street.Hoosier 26x9.5 slicks on the strip.
Old Sep 23, 2000 | 03:03 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
I was told (by a race engine shop)that the stock rods(machined/smoothened)and good bolts are good for 500HP and up no more than 6K RPM .Also that they are the powdered metal type.I used the L98 rods on my stroker
Daz
L98 block and rods,10.4:1,Hypers,SCAT crank
TFS G1 heads 5 angle competiton valve job
Crane Gold roller rockers
Comp cams276H-R14
TPIS Bigmouth base
Superram
52mm TB...
MRP chip(oldie but goodie)
synthetic oil(LOL)
Old Sep 25, 2000 | 09:23 AM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
I have a set of new LT4 PM 5.7 inch "pink" rods for my 383. Is it worth installing ARP Waveloc Pros and then paying $80 for resizing?
I'm shooting for 6500 RPM operation in conjunction with a Miniram.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines,
5-point racing harness, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Speed-sensitive steering conversion, underdrive pulleys, Crane Hi-6 & more. 1.05g skidpad verified.
New best E/T! 14.400 at 98.6 MPH in 88 degree air at Stanton, Michigan.
Old Sep 25, 2000 | 10:12 AM
kevinc's Avatar
Car: 1982 Z28
Dan-
The only reason I replace rod bolts is if they're used. I have a strict "no used rod or head bolts" rule as these things stretch quite a bit while being torqued. And...any time I replace rod bolts I use ARP wave-locks.
If your new rods came w/ new bolts, I'd use 'em. I have never, ever heard of a rod bolt failure on an LT1/LT4 even w/ nitrous, blower, etc.
-Kevin
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
Ed1LE
Sep 30, 2018 09:14 AM
FormulasOnly
Jul 23, 2018 08:47 AM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
