Cams.....
Old Sep 25, 2000 | 01:23 PM
Formula92's Avatar
Cams.....
I recently aquired a Crane Cam and Roller Lifter set. Don't know when i'll be installing but was curious as to weather anyone out their has the same set-up and what differences you saw after the cam installation. My signature is at the bottom. The current cam is the hotter cam for the 305HO @ 202/207 @0.50 lift. Max lift is 415/428 with a lobe sep of 114.5
The Crane is part # 104225
208/214 @ 0.50 Max lift is 438/452 with a lobe sep of 112.
Thankx for any input.............
92 Formula,305HO,Factory Oil cooler,Hyper-Tech Chip,Hyper-Tech Coil kit,Dual-Core Split-Fire wire set,Hyper-Tech Airfoil,Accel Fuel pressure guage mounted on fuel rail,Crane Adj Fuel Pressure Reg,March Performance Pulley set,Four Wheel Disc Brakes,WS6 Package,Dual Convertor Exhaust,3.42 Gear/w POSI,5Speed Borg Warner Tranny,Center-Force2 Clutch Set-Up,K&N Filter.
Old Sep 25, 2000 | 05:41 PM
NICK 86 TPI's Avatar
i have a 86 305 tpi with similar mods
i also have fully modded exhst and a 700r4
before i did the cam i was at 15.2
after the summit 86 tpi cam kit (204 214, 420 442)and fastchip, i am running around 14.6, but i have two mushroomed valves, so it could be better
88fastgta
Oct 16, 2007 01:39 PM
