Air Intake
Old Sep 26, 2000 | 09:41 AM
Formula92's Avatar
Air Intake
I am thinking about buying a K&N filter that attatches to the front of my throttle body,305TPI. Is it worth the change and what differences did you feel? Right now i am running a K&N in the stock location.
Thankx,,,,,for any input..
92 Formula,305HO,Factory Oil cooler,Hyper-Tech Chip,Hyper-Tech Coil kit,Dual-Core Split-Fire wire set,Hyper-Tech Airfoil,Accel Fuel pressure guage mounted on fuel rail,Crane Adj Fuel Pressure Reg,March Performance Pulley set,Four Wheel Disc Brakes,WS6 Package,Dual Convertor Exhaust,3.42 Gear/w POSI,5Speed Borg Warner Tranny,Center-Force2 Clutch Set-Up,K&N Filter.
Old Sep 26, 2000 | 11:28 AM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
If you put that filter on your TB you will be sucking in hot engine bay air and may lose some power. Keep your stock set-up for now and gut out the lower air box, maybe even do the ram air mod.
Convertible, L98, Edelbrock intake, runners & TES, SLP cam, Thin Head gaskets, March underdrive pulleys, Fastchips custom chip, Accel 300+ ignition, Relocated MAT sensor, TPIS airfoil & AFPR, K&N airfilters W/ chopped airboxs, Dynomax high flo cat, Flowmaster exhaust, MAC subframe connectors, B&M shift kit & XMSN cooler and NOS!!
Old Sep 26, 2000 | 12:08 PM
Formula92's Avatar
That's what i thought also, did you cut a large suqare hole in the canister. I did drill three holes in the bottom but they probably could be larger. Problem was that my drill wouldn't hold that large of a bit. After drilling i found a filter normally used for a air cleaner that fit perfectly around the bottom. Looking forward to hearing from you.
1992 Trans Am
May 10, 2023 07:19 PM
stalkier
Dec 6, 2015 11:25 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
