My cars idle speed is 1500 in park HELP!
Old Jun 2, 2007 | 08:24 AM
djdryice's Avatar
Can someone please helpme!?! i have a 1986 Camaro 305 Tpi,when i turn the car on it idles at 1500 rpm's, and in drive it idles at 1000 rpm's, i have a automatic transmission, can someone please give me imformation on how to lower it!!!
Old Jun 2, 2007 | 04:00 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
Re: My cars idle speed is 1500 in park HELP!
sounds like a big vacuum leak somewhere?
Old Jun 2, 2007 | 04:05 PM
shocker89bird's Avatar
Car: 89 ws6
Engine: 355 afr195, hsr,gmpp cam, hs rr,
Transmission: t-5
Axle/Gears: 3.08
There is a good chance your throttle body is sticking as this is a common problem with stock trottle bodies on tpi. The spring has a tendency to wear out and stick in a more open postion.
Old Jun 3, 2007 | 09:12 AM
djdryice's Avatar
ok i just ordered a new tv cable and i guess ill have to get a new spring too! and its def not a vacuum problem because you would be able to hear the air leak, it would hiss really loud but thanks anyway for your reply
Old Jun 3, 2007 | 11:30 AM
Car: 89 ws6
Transmission: t-5
Axle/Gears: 3.08
dj a good way to test this is if it is stuck while you are cruising around if you hit the gas really hard if the idle comes back down. There is always a chance it is your IAC too. Check the spring first it is the easiest thing to check then work towards the electronic parts.
Old Jun 4, 2007 | 12:49 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Pull the snorkle off to look at the tb, if it isnt stuck open its probably fine. Check your tps, should be at 5.4v, could be a bad IAC also. There is also that adjustment screw where the throttle cable is.
Old Jun 4, 2007 | 07:17 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Originally Posted by Rayzor32
Check your tps, should be at 5.4v.
.54v
specialized
Jun 18, 2022 09:26 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
kyleb24
Aug 15, 2015 08:24 AM
killer777
Aug 8, 2015 02:47 PM
