Severe bog
Old Jun 2, 2007 | 11:28 PM
8690zroc's Avatar
Severe bog
i have an 86 z i just aquired from a family member and it has the worse bog i have ever seen when i hit the gas it just almost dies and sounds like it is sucking air real bad i check for vacume leaks replaced the oxygen sensor , cap,rotor,wires,plugs,and maf and it still does it i need help here i cant figure it out , i know it had some engine work done might even be a vette swap because the cap is for a vette it has the screws instead of twist locks and ideas will be appriciated thanx
Old Jun 3, 2007 | 09:25 AM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Re: Severe bog
make sure the intake tube around the maf is tight, and that there are no rips in the tube. Especially want to make sure there are no leaks AFTER the MAF sensor, as this will register as unmetered air, and cause problems like you are describing.
Old Jun 3, 2007 | 04:37 PM
8690zroc's Avatar
Re: Severe bog
thanx for the tip, But that isnt it i check that all out and there is no leaks but i did notice on the egr solinoid there is a spot for a hose on the oposite side away from the egr port i cant even find a schematic to show where this hose even went nor can i find a loose one on the car
Old Jun 3, 2007 | 08:08 PM
Iroc_man's Avatar
Car: 87 Iroc
Axle/Gears: stock posi
Re: Severe bog
egr valve, fuel filter, timing off maybe?
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
Grant2k
Apr 4, 2016 08:21 AM
88CamZ
Oct 8, 2015 10:29 AM
HoosierinWA
Oct 7, 2015 10:15 AM
