BBK ,Holley ,or Edelbrock 52 TB?
Old Sep 27, 2000 | 07:29 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Which one? I always thought BBk and Edel were the same but there is a 40 buck price differance.
Old Sep 27, 2000 | 08:49 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I also thought they were the same! anyone know?
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTB, ported plenum, 52 TB, MSD 6AL, TPIS level V prom, Mod .MAF, Superior shift-kit and some minor mods. and more to come!
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Old Sep 27, 2000 | 10:28 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Edel and BBK are the same. I have the Holley and am happy with it but I really see no difference between that and the BBK. If I remember correctly the BBK is even cheaper than the Holley so I would go with BBK. Hope that helps a little.
Old Sep 27, 2000 | 11:19 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I had the BBK and the top plate didnt say edelbrock any more and when I asked summit about prices They had an edelbrock one for 329.99 and the BBK for 299.99 They are differant part numbers and all.
Old Sep 27, 2000 | 05:52 PM
rondubbs's Avatar
mine says bbk edelbrock on it!!
Old Sep 28, 2000 | 02:18 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I just bought a BBK 58mm TB and IM happy with it. What ever brand you get look it over good. check the threads, and make sure the plates dont bind in the bore. These are some of the problems Ive been told about that you can incounter with TBs.
The cleanair cover on mine says "BBK POWER-PLUS" I wondered about that. The ones Ive seen all said "BBK/ELDEBROCK".
Good luck!
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Sep 28, 2000 | 02:23 AM
Dan87IROC-Z's Avatar
I dont think it makes a difference, the TPIS one is only like $280 out of their catalog and I think it includes the air foil.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Components, K&N Filters, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.3 @ 97mph
(corrected for elevation)
Old Sep 28, 2000 | 05:49 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
The TPIS tb is $280 and you have to send them your old one, apparently they hone it and put in new butterflies. Also do any of the other ones include the IAC housing or do you have to use the old one??
'86 TA, T-tops, T-5, 3.73, 4 wheel disks
350, compucam 2040, performer intake,SLP Headers, 3" race magnum muffler, 1.6 Comp rockers, Ripper shifter,
perf. friction pads, Hypertech ignition, Earls brake hoses, Hotchkis springs, Tokico Illumina 5 adjustable
shocks and struts, Lakewood panhard and trailing arms
14.73 @ 95... traction still a problem
Old Sep 28, 2000 | 06:00 PM
rondubbs's Avatar
you use the old iac housing.
Pac J
May 17, 2020 10:44 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
Royal_Z
Sep 30, 2015 08:45 PM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
