MINI RAM, SUPER RAM, PORTED PLENUM ?
Old Jun 3, 2007 | 07:48 PM
T/A IN PA's Avatar
Car: Trans am
Which one would work best? A TPIS MINI RAM, ACCEL SUPPER RAM or a ported stock plenum on a 92, 305? Also what type of head will i need to make it complete? Would I need bigger fuel injectors for this setup?
Old Jun 3, 2007 | 08:46 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Re: MINI RAM, SUPER RAM, PORTED PLENUM ?
Ported plenum would be fine. Miniram and superram would be overkill. Stock injectors would be just fine.
Old Jun 4, 2007 | 11:56 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Along with the heads don't forget to add the block and pistons.
Old Jun 7, 2007 | 03:43 PM
T/A IN PA's Avatar
Car: Trans am
Oh and the spark plug wires too!
Old Jun 7, 2007 | 04:56 PM
Detroit_Z28's Avatar
Car: 91 Z28
Engine: L98 350
Transmission: TH350
A Kneuter Valve, flux capacitor and muffler fluid are required too or stuff just won't work out right.
Old Jun 7, 2007 | 07:08 PM
brutalform's Avatar
The stock TPI was actually designed for a 305, so its not flow limited, unless you have a real hot 305.
tyeo098
Nov 30, 2015 06:27 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
Nick McCardle
Sep 10, 2015 08:36 PM
09ave
Sep 7, 2015 06:03 PM
