PUFF AND SMOKE (need help quick)
Old Sep 28, 2000 | 09:34 PM
Transformer's Avatar
OK I just finished putting my car together. My problem is that when its on it backfiring and throwing out black smoke.
It is an 88 GTA 5.7 and I have done some pretty extesive mods which were done all at the same time. I dont think the mods are my problem but just in case this is what I put in it. 58mm TB , ported plenum, SLP runners SLP 1 3/4 headers, Edelbrock base, ported heads,210-220-480 cam,and an ATI procharger but i have the belt off right now till i get the engine running right. I get no codes on the computer so IM stumped. I have checked timing,and firing order. any advise will help.
88GTA 5.7(under construction) ATI Procharger,58mmTB,ported plenum,SLP runners,Edelbrock HI-FLO base.ported heads,1.5RR,210/220/480 compcam,AFPR,SLP1 3/4 headers,3.70 gears,Eibach drag launch,Lakewood LCA`s, Nitto drag radials.
Old Sep 29, 2000 | 08:25 AM
Bill91Z
Guest
Posts: n/a
Might need a custom PROM with that cam. Although it''s not radical by any means, it may be big enough to merit a custom PROM. Black smoke usually means you are rich. Could also be an MAF problem, but you are throwing no codes. Make sure that the distributor is in right also, could be 180* off.
-Bill
-=ICON Motorsports=-
Boston Chapter
91Z28, (in progress) 3.8L, TE63-1 turbo, MSD50lb injectors, Hemco upper, ported TTA heads, 62MM TB, Red's XP fuel pump, 3.73s, vigilante (stall to be determined)
Old Feb 20, 2003 | 02:19 PM
fbodyking's Avatar
Sell it and get something new!
Old Feb 20, 2003 | 05:05 PM
rezinn's Avatar
Its backfiring through the intake or exhaust? Is your harmonic balancer fairly new? I had similar problems, realized that my balancer slipped and my timing was off. I would say that you definitely do need a custom prom with all that work. You're sure you've got the valves set correctly?
F-body-fan
Jan 12, 2023 01:49 PM
FormulasOnly
Jul 23, 2018 08:47 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
